390" LS Engine
11 Second Club
The base block is a standard 6.0 iron (you can also build it with a LSX or aluminum block). The stroker rotating assembly uses a crank with 3.825" stroke instead of the usual 4.000" stroke. This is supposed to make it stronger than a 4.000" stroke due to more crank journal overlap and thicker ring landings in the piston.
https://ls1tech.com/forums/forced-in...rankshaft.html
VERY WEIRD! I started this post yesterday and it deleted my op. Here is what I posted:
AES 390ci - Now with Callies Dragonslayer crankshaft - LS1TECH
Anyone run a 390" combo in a truck/suv? Specifically, a forced inducted application?
Thanks man! I wasn't sure where to post it since it is an engine question, but also really concerns forced induced combos.... Thanks again.
superchomper2003
08-26-2015 09:39 AM
GMCtrk
38
08-09-2015 08:50 PM
85SS/85GN
07-22-2015 12:48 PM
