4.8 or 5.3 for boost?
Old 11-21-2008 | 10:43 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by Wilde Racing
That is true, If you could, a L33 pile would be they way to go, other than 6.0.
you said Pile, as in Nuclear reactor pile, right?
Old 11-21-2008 | 10:46 PM
Stoichiometric's Avatar
When the engine detonates it acts more like a pile driver. Shortens the rod a few inches at a time.
Old 11-21-2008 | 10:51 PM
trever1t's Avatar
shorter rods will alllow for higher rpms....crank it up!
Old 11-21-2008 | 10:54 PM
kbracing96's Avatar
Now your making stuff up! shorter rods = more rod angle= worse for RPM But it lowers compression so you can run more boost
Old 11-21-2008 | 10:56 PM
trever1t's Avatar
busted
Old 11-22-2008 | 12:56 AM
Wilde Racing's Avatar
How do I change this text
A few inches? DAMN how long are those rods???? Is the mean piston speed changed in anyway after this so called rod shortening process?
Old 11-24-2008 | 01:11 PM
ls3s10's Avatar
my 08 on 12 lbs made 438 on very safe tune little 4.8 with headders, injectors and fuel pump. and 08 4.8 is 9.0 compression
Old 11-24-2008 | 01:14 PM
nighthawk08's Avatar
everyone in this thread is referring to old 4.8 vs 5.3 most of which is invalid for the Gen IV engines.
The 08 4.8 is roughly 9.2:1 compression, probably flat top pistons, 243 heads.
The 08 5.3 is roughly 9.9:1 compression, probably flat top pistons, 243 heads.
if he strickly wants to run boost and can't located a 5.3 RCSB the 4.8 would be a fine choice.
Old 11-24-2008 | 05:07 PM
L7 Sierra's Avatar
4.8's are just fine and so is McCormick Vodka, but I think a 6.0 swap witf 8.5 cr is much much better
Old 11-25-2008 | 01:21 PM
Noah Burns's Avatar
8.5:1 is going to leave power on the table... it will be VERYYYYY safe, but leave a lot on the table too I think. 10:1 would be my starting point, get the tune right, run the right gas and you're good to go.
