4.8 Turbo (Coming Soon) Need Some Critiquing
#21
How do I change this text
I believe autometer uses the dynojet stuff.... The old dynojet commander 1 used an autometer gauge.
Smokeshow is right, you can make a ton of power with one 3" exhaust. I'm not saying your dyno numbers will stop right at the point of max exhaust flow through the pipe, those numbers are just general calculations of when the pipe will become restrictive. As usual, there is a ton of other factors involved like max RPM, exhaust temp and velocity, radius of bends, length of pipe, completion of combustion, pipe wall thickness are just a few. (and about all that I understand, I'm sure there are many more factors...)
You can easily go bigger than 3.5", look for some diesel cat back systems. They are typically 3.5" min and really easy to find 4+". Which brings up another point on exhaust size; Why do you think diesel exhaust is so large when the engines are typically the same size litre wise, but only turn about half the rpm?
There is a point of diminished returned with larger exhaust size, at some point the exhaust velocity slows down and the exhaust gas cools becoming more dense... If you really wand 700hp stick with 4" it really isn't that hard to fit... TRUST ME.. lol
#23
BoostedBowTie
01-03-2020 06:46 PM
03regcab sierra
20
08-03-2015 12:11 AM
