4.8l 13.5 PSI: Tuning, IAT/Intercooler, 1/4mile time question
Old 11-02-2015, 11:46 AM
  #41
fastjweb's Avatar
Originally Posted by stock48
Thing needs the stock intake on it and some meth injection or E85 and 15~16 deg of timing to start with. The triple 12 cam will rev to 6800 RPM in a 4.8L long as the springs are set up right. Single pac's will need a .030''~.-45'' ship to reach that rpm, BTR duals should be fine at std height. If you want to make power on low boost like 13 psi the thing is going to need some timing and a leaner AFR. That turbo is pretty small on the exh side but still should reach goal or faster if things are right. The reason the converter slip is so high is because there is not enough RPM there for it to couple with that gear ratio and mph. Get mph up around 130+ with more power and it should couple a lot better.
Smart man!
Old 11-02-2015, 08:54 PM
  #42
lycominghunter's Avatar
Thanks Jarrett, as well as everyone's else's inputs. I'll be going to dragging rights this weekend on the set up I've been running - hoping to get a high 11sec out of it. But after Saturday it'll be 4.10s and a stock intake. I'm interested to see the difference!
Thanks again gents!
Old 11-03-2015, 01:17 AM
  #43
9 Second Truck Club
stock48's Avatar
Easiest thing to do right now is mix some race gas in it and bump the timing to 17 deg and don't let it pull any for iat. Meth inj or E85 would be better but I bet the timing will be worth huge power and it will have a lot more top end as well. Id prob shift it around 6500 RPM if the springs are not shimmed.
Old 11-15-2015, 06:02 PM
  #44
Thanks for all of the help gentlemen. Just wanted to get back to y'all and close the loop on this issue. I wrapped the up-pipe and Turbo Inlet pipe in 1/8 foam insulation and then covered that in foil tape. Next I built a head shield for the air filter. Now, the temps have gotten cooler since I last ran, however I think the insulation helped to keep IAT's to 122 degrees by the end of the run, so I'll consider that a win.
The truck is running around 10.8AFR and is currently on 15 degrees of timing. Currently shifting at 6800rpm.
Stock48, the springs are shimmed per your recommendation back in 2013 when I bought the triple 12.
Results: 11.67sec@117.1mph, 1.74 60ft leaving at 3500rpm and 10psi. DA ~ -500ft
I'm pretty impressed. With those numbers, the negative DA really helped. 4.11s should be done tomorrow, but wont know any improvements or track times until December.
Thanks again for all of the help!
-J
Old 11-15-2015, 07:14 PM
  #45
12 Second Club
1979rs/z28's Avatar
I doubted those 3.42s till our mexico trip the other night! that truck felt really strong! good job man!
Old 11-15-2015, 07:28 PM
  #46
fastjweb's Avatar
Yes, awesome job J, and thanks for help and slicks today.
Old 11-15-2015, 08:07 PM
  #47
smokinlmm's Avatar
Dam, nice run! I cant wait to get started on a rcsb myself.
Old 11-16-2015, 09:53 PM
  #48
HAHAHA Mexico. Well no more 3.42s, see what the 4.10s will do now.
Thanks for the congrats guys!
RedDeadG8
26
12-01-2015 11:32 AM
03chevytruck
08-25-2015 09:08 PM
lxcoupe
08-24-2015 08:16 PM
The_W
08-18-2015 04:57 PM
Quick Reply: 4.8l 13.5 PSI: Tuning, IAT/Intercooler, 1/4mile time question
