408 roots blower build
#103
what a rush!
Well i have a kick *** looking engine atleast. Well the engine didn't make near as much as i thought. With the roots blower i knew it wouldn't be a power horse but i'm not impressed much. Anyways here's the results.
6 lbs boost 25* timing 9.0 A/F ratio 88degrees AIT start to finish of pull= 705.2HP@6,500rpm 664.4TQ @4,700 rpm.
9 lbs boost 23* timing 8.5 A/F ratio 126 degrees start and 162degrees AIT end of pull= 732.5HP@6,100rpm 667.5TQ @5,200 rpm.
15lbs boost 17* timing 8.0 A/F ratio 183 degrees start and 209 degrees AIT end of pull= 722.9Hp@6,300rpm 678.3TQ @ 4,600 rpm.
Any input or suggestions? I have tomorrow morning yet to dyno if needed. I'll try to post dyno sheets and videos soon.
Gotta start somewhere I'd like to see a higher boost run with lower starting IAT's. Have you thought about adding a interrcooler?
http://www.theblowershop.com/product...R-71-SERIES-1/
#104
Ok so what should i set the A/F ratio at and timing for a 15.5 psi pull?
I also have a 19psi setup i can put on. What recommendations for timing and A/F for that?
The 9lb pull produced the most hp and ait were not to bad and changes to the timing or A/F on that setup?
#105
I'm thinking of a 19lb run 1st pull this afternoon. That way the ait's will be down and not up there from the previous 4 pulls. Hopefully the ecu won't pull timing this way. What's your thoughts for timing and A/F for the 19 lb pull and also for the 15lb pull?
#106
11 Second Truck Club
I would run 17 deg. And equivalent of 11.2 or so afr. Depends how the ecu alters timing with iat. IMO that should be safe. I run 21 deg. at equivalent of 11.9:1 at 14 psi with e85. Seems like you can go a touch leaner with e85 than gasoline. Don't blame me if something happens though, lol.
#107
#110
Also, he has injectors both pre and post blower, so meth would hardly benefit in this case, however an intercooler would do wonders. If you want to get the good number, you have to run high boost setup first run. Maybe even warm it up to get the oil temp where you want it, then let it sit for 15 minutes with some ice cold towels on the blower, you'll be amazed. Icing my blower in the pits took 1-2 tenths off my runs every time.
