416 stroker turbo
Old 11-29-2015, 06:19 PM
  #21
caviness's Avatar
also I know ill need to change the gear to but what to , its my daily but that's only about 50 to 100 miles a week normally so I might lean a little more towards the track on the gear , ill be running 20s on the street and if I go track ill be getting me a bogarts setup on 16 and 15s
Old 11-29-2015, 06:23 PM
  #22
caviness's Avatar
Thanks for all the info so far. the turbo stuff is new to me on cars and trucks but know a little about my big trucks I got with 60 series Detroit I run BW 171702 on them to keep the exhaust free flowing but they boost around 40 psi
Old 11-29-2015, 06:27 PM
  #23
caviness's Avatar
the motor that's in truck now was in my Camaro and it run 6.60s on 150 shot and 7.30s on motor so the truck eat up a lot of that just taking the motor and trans out of car and putting in truck lost a lot of get up and go.
Old 11-29-2015, 06:30 PM
  #24
caviness's Avatar
on the convertor I can send that back and get it restalled or get another one
Old 11-29-2015, 06:33 PM
  #25
caviness's Avatar
George c , Atomic thanks I been reading a lot of yalls builds and stuff bad *** trucks for sure
Old 11-29-2015, 07:51 PM
  #26
Hunt&Fisherator
silver-mod-o's Avatar
I'd consider a T6 kit from KBRacing. You can still run a medium frame turbo (even with a T4 adapter if needed) and have the hot side already there if you wanted to upgrade down the road with a bigger turbo etc. this way, the kit is purchased once and you're done.
Old 11-29-2015, 08:30 PM
  #27
caviness's Avatar
sounds like nice kit
Old 11-29-2015, 08:40 PM
  #28
Truck Sponsor
TrickTurbo's Avatar
Give me a shout to go over your build and your requirements.
940/781-5204
--I recommend Being realistic on your goals.--
Many assume people want more later in life because they wanted more.
While others build for 1000+ hp but never get there or run out funds else where.
Then that kit is too big and just a big giant POS on the street.
Kit should be built to match the goals and have the ability to upgrade with ease when the time is right.
Old 11-29-2015, 08:50 PM
  #29
caviness's Avatar
Thanks ill give you a call later this week
Old 11-29-2015, 09:29 PM
  #30
I have a gauge for that
Atomic's Avatar
Pretty much sums it up right there. A lot more goes into building a 1000hp truck than just turning up the boost controller. Even 800 is rowdy on street tires in a truck, not something to be taken lightly.
The s400-84/96 sounds like it might fit the bill for what you want though, will spool decent on the street and make 1000hp on your motor with it turned up.
Quick Reply: 416 stroker turbo
