4L80E will I lose power??
i am going to pickup my truck today and try to take it to the track for the first time on the new setup. befor the 65 went out it pulled its *** off when it went to 2nd gear. but i have heard that an 80e has a longer 1st gear in it? it beeing a bigger trans will i lose a lot of power or is this a dumbass ?...?
thanks
thanks
you feel like you loose power but it makes up for it one the other side! Mine is sluggish out of the hole but it mph's like a champ! I actually like mine more than the 60 with the yank 3000 because it will leave more predictable and less spinning!
I know I lost a little fuel eco. That may be due to the 80's shorter O/D ratio vs the 60 though. Does seem like it takes more power to get down the road. I didn't do a dyno before and after. I'd be surprised if the 80 didn't dyno a little less. The upside is that the 80 has been running trouble free for thousands of miles. Even a "built" 60 is prone to failure if you put a little boost on the motor in front of it.
Rick
