4x4 Traction
Old 03-29-2010, 03:53 PM
philntx's Avatar
Default 4x4 Traction
Has anyone seen this sport truck article?
If anyone has experience with this modification, can you share how it is engineered?
http://www.sporttruck.com/featuredve..._427ci_v8.html
Says he's from Baytown TX
Interesting article on traction in a Silverado, 600 horsepower 2006 Corvette LS7 427ci V-8 / 90mm intake and heads ported and polished / custom camshaft with .239 intake and .268 exhaust lift @.050 inch with a 116 degree centerline / Kooks 1 7/8-inch headers / Aeromotive A1000 electric fuel pump / Speedtech dry nitrous and plate nitrous systems (275 HP shot)
Rather than run slicks, Paco swapped in a 4x4 system taken from an '08 Chevy Silverado Z-71. Four-wheel-drive on a lowered truck-that's what we were wondering. According to Paco, he engages the automatic system using an MSD timer that keeps the four wheels working for approximately two seconds during holeshots and then switches to two-wheel-drive mode once the truck gains traction. The system eats up a bit of power due to parasitic losses but more than makes up for it by keeping the tires from spinning obnoxiously while the competition takes off
Old 03-29-2010, 04:17 PM
1989k1500's Avatar
I dont see how it would work, everything should need a signal to disengage it.
Its not like the front actuator gets power held to it the entire time it is engaged and if you just cut power it disengages, it needs to be powered the other way to disengage it.
Old 03-29-2010, 04:56 PM
xXxSilveradoxXx's Avatar
What's wrong with just manually switching to 2WD before you shift into third?
It kinda surprises me that he went through all of the trouble to swap to 4WD, especially since he supposedly has 405s on the back.
Old 03-29-2010, 06:58 PM
wentbig's Avatar
My 7100# 2500HD runs 14.60 with a 1.99 60' in 4X4 with-out 4X4 it boils the tires.
He may think he is shifting out of 4 wheel drive but...as long as there is load on the drive train it will stay in 4 wheel, then when you back off it will shift.
NO RIG will shift in or out of 4 wheel under load, unless it is a Full time AWD
Old 03-29-2010, 07:00 PM
1989k1500's Avatar
Mine would shift out just fine at WOT. I would hit the button just after the 1-2 shift. If I didnt it would lose a few mph.
Old 03-29-2010, 07:05 PM
wentbig's Avatar
Smile
Are you positive the T-case shifted or did the light just go off?
I am afraid I will Break something doin that.
do it a few more times and see. then I will try it.
Old 03-30-2010, 11:04 AM
Sambo53's Avatar
Mine does the same thing. I hit the button after the 1-2 shift and the light blinks a bit then goes in 2wd. I used to think it was still in 4wd until I forgot to turn it off one time and I lost a few mph in the 1/4 at the track. Its kind of strange though, some trucks seem to be able to shift out and some dont.
Old 03-30-2010, 12:52 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
mine shift out just fine too....ask me how I know?
Old 03-30-2010, 02:29 PM
1989k1500's Avatar
It shifted out. I left it in one time and lost 3mph IIRC. I did it probably 3 dozen times, everytime I ran it at the track plus a few times on the street.
Just like these guys'
Old 03-30-2010, 05:18 PM
02'Z71ONDUBZ''s Avatar
Soooo... are we talking 4HI or Autotrac launches? Prob a dumb question, I know...
Quick Reply: 4x4 Traction
