5.3 on 20psi
Old 01-02-2013 | 05:52 PM
  #41
Mangled03gmc's Avatar
Baltimore Whore
Damn you guys are seriously pushing these things. I need to get the 80 swap donem, so i can hit this bitch with more boost. I wonder what 12 to 15 lbs will feel like.
Are you running studs?
Old 01-02-2013 | 06:15 PM
  #42
blue0453's Avatar
What turbo are you running 02camaro.
Old 01-02-2013 | 06:28 PM
  #43
Running the cxracing 80mm. Its the exact turbo as the magnum 80mm but half the price. It has a 77.mm turbine exducer. Its sick as hell. I'm running arp studs and ls9 gaskets. On 13 psi it has to be at least 650 rwhp.
Old 01-02-2013 | 06:36 PM
  #44
blue0453's Avatar
What would I need to swap. Currently running mp76 3" dp.
Old 01-02-2013 | 06:56 PM
  #45
You will need a 4" downpipe with a 4" V-band flange and you will need to do some work on the cold side because the outlet is 3.5" v-band. Also the inlet is 5"
Old 01-02-2013 | 07:00 PM
  #46
blue0453's Avatar
Wander if it would be worth the effort.
Old 01-02-2013 | 07:15 PM
  #47
It was for me. The mp76 and on3 76 are basically the same. With the new setup it feels a lot better on 12 psi than the old one did on 14.5 psi. Plus the mp76 will be maxed out around 15 psi on a 5.3. This new turbo will really start to shine around 15, but it already feels great on 12 and 13
Old 01-02-2013 | 07:23 PM
  #48
blue0453's Avatar
Well now you have me thinking. Might have to sell the mp and 3" dp.
Old 01-02-2013 | 11:06 PM
  #49
I assure you that you wont regret it
Old 01-03-2013 | 10:22 PM
  #50
TRD_Tundra's Avatar
Damn what gears and stall do you have?
