5.3 boost and timing
hey guys im FINALLY going to get my truck dyno tuned on monday. I have a stock 5.3, 4l80e, zo6 cam and springs, and 241 heads which should bring compression down to 9.1 or 9.2-1. custom front mount with mp70 turbo, intercooled. what do you think would be a good boost/timing combo? i want to run 10 lbs and im debating e85(105 octane). I can get it for $2.79 a gal, and prem is 3.99+. any guess on the numbers? thanks
dyno #'s https://www.performancetrucks.net/fo...d.php?t=418618
8 Second Truck Club
you running meth? I would be safe and sneek up on it. Maybe start around 15* and add from there. A thing to remember, my truck will handle alot more timing on the dyno than it will on the street because of engine loading. There is alot less engine load on a chassis dyno. Besure when your done to do some actual road testing to make sure it won't knock.
ok guys thanks for the info. i wont be running meth but will be in the future. i think my tuner said we would go drive it on the street and log some runs. I will let you guys know what the numbers are tommorow
15-18 deg.
Raggedz71
07-29-2016 10:20 AM
