5.3 cam to ls6 cam high boost dyno results
Old 05-27-2007 | 11:37 AM
LARRY01Z28's Avatar
ok whats the results??
Old 05-27-2007 | 11:41 AM
kbracing96's Avatar
Originally Posted by parish8
dyno is scheduled for 8pm tomorrow
Some people should learn to read,
Old 05-27-2007 | 01:06 PM
PappyDan's Avatar
Tribe Shaman
well post up a before and after so we can see how much the power curve changed
from the stock cam to the 01 LS6 cam.
Old 05-27-2007 | 05:42 PM
LARRY01Z28's Avatar
ok i dont knwo what time zone hes in. so his 8 pm could be my 5 pm or 11 pm. or anything like that.
i was just saying post up the results after he was done.
Old 05-28-2007 | 04:20 AM
parish8's Avatar
single digit dreamer
just got back. good god!!!!!!! first pull at low boost was very impresive. up top we ended up maxing out the turbo so we couldn't even get back to the same boost level we had before the cam swap so it isn't all that great of a test but at the pump gas level it is a great before and after test. the change is hardly believeable.
Old 05-28-2007 | 04:40 AM
Spoolin's Avatar
GFYS and STFU
Numbers numbers numbers???
Old 05-28-2007 | 04:49 AM
PappyDan's Avatar
Tribe Shaman
damit jim, **** like this frys my nerves when you keep it to your self.
spill the beans man, what did it do.
Old 05-28-2007 | 05:00 AM
Spoolin's Avatar
GFYS and STFU
What does a dyno sheet look like when it's maxed out the turbo? And how do you determine that it's the turbo that's maxed out...simply because you can't attain the boost levels? Would a bigger A/R help?
Old 05-28-2007 | 05:08 AM
nonnieselman's Avatar
I cant read... its gettin too late and ive gone way too long without sleep....... I thought i read Dyno... not Turbo...
Good Deal Parish, Looks like i found my next Mod......
parish8's Avatar
set up. mp70 turbo, stock 5.3 other than springs, t400 with an overly loose converter.
first chart is a real good before and after test of a stock 5.3(blue) cam vs a 2001 zo6 cam(red). minimal variances, the numbers prety much speak for them selves. WOW!!! this is our max pump gas setting
next chart isn't the greatest comparison but you definately get the idea. we ran out of turbo so we couldn't get to the same boost level. you can see we are up 48peek hp even though we are down almost 4psi. does this seem insane to anyone cause it doesn't seem possible to me. at 6100rpm we are up 87hp even though we are down 5psi
last chart is us maxing out the turbo. there is a funny story here. we had a 6psi spring in the wg and though it might just be out of spring so we swaped in a 13psi spring. we forgot to hook up the boost refrence line to the wg , the thing should have hit 30+psi but it didn't go up at all from what we were seeing with the 6psi wg spring and the boost controler at 100%.
you can see where the boost went up some. the exhaust back presure went way up. even with quite a bit more boost we only made a few more hp. the iat's were going up quickly too. the wg was esentialy blocked off.
we are not going to run it at this maxed out setting since it is only gaining us a few hp. probably run it at a max of 15 or 16psi. right now we are likely near the limit of a pile of other things on the car so steping up to a better turbo to get more power doesn't make much sence. now iguess it is time to get this power to the ground
