5.3 turbo'd guys come in
Old 08-08-2014, 12:27 PM
Blackpanther99's Avatar
Whoa that was quick and alot of good info. I appreciate that guys
Well I already have the 4.11s soo ama stick to those and later change things around. I also have a 3800 triple disk which I will be sending off to PI to get it tight for boost.
Btw truck is a 6 speed soo it has that short 1st gear soo my truck from digs could be useless
I think just a cast wheel wil get it done, I dont think a race cover is necessary.
Originally Posted by Atomic
bw 76/87 would be a good one for that. Much better turbo than the on3 flavor.
Ill take a look at that. Thanks man.
Old 08-08-2014, 12:29 PM
Originally Posted by black00chev
Like Atomic said, something right around the 76mm compressor size should be perfect for that. Ive got a 70mm waiting to go on mine, but I sized it more for DD/towing duty than for highest performance.
I would also considering dropping down from a 4.10 to like a 3.73 or 3.42 gear. It'll help load the turbo up better.
You also really don't need to get the heads ported. With the right turbo/cam/gears/stall you should have no problem hitting 600hp without digging too far into the motor.
Soo no head porting? Not really looking towards CNC porting because of the price, but I do know someone locally that does great hand porting for a good price. Should I leave them alone then? A lil extra HP is more than welcomed
Old 08-08-2014, 12:31 PM
S475/83 will be moar than plenty and have a lot of room to grow.
BTW, i'm faster with 4.10's than 3.42's.
Soo many units to choose from hmmmmmmmm
I have a gauge for that
Atomic's Avatar
I wouldnt bother at your stage personally. Run 1 more psi of boost and it will make up the difference.
Old 08-08-2014, 12:32 PM
Gotcha
Old 08-08-2014, 12:35 PM
Slowest turbo build ever!
black00chev's Avatar
Yea unless you are all ready sending them out for anything I wouldn't bother touching the heads. Our trucks need as much power and torque down low that they can get.
Old 08-08-2014, 12:41 PM
Ok thanks for the tip bud.
Old 08-08-2014, 12:51 PM
Yea if you were looking to get every available HP out of it than of course get them ported, but that can be a few bucks better spent somewhere else if you aren't going all out.
Old 08-08-2014, 12:52 PM
Yeah ill use that for injectors and rest of fuel system which wont be enough but hey its something lol
Quick Reply: 5.3 turbo'd guys come in
