5.3L Turbo Build
Old 01-18-2009, 11:15 PM
Djaustin89's Avatar
alright, thanks. rather be safe. what about stronger replacement valves for the heads?
Old 01-18-2009, 11:47 PM
Stoichiometric's Avatar
I haven't really heard of anyone burning valves, usually a ring land will crack on a stock piston.
Old 01-19-2009, 09:38 PM
Djaustin89's Avatar
hey Bill, how much are you making with your t66? would that be a decent turbo for me or something else?
Old 03-27-2009, 04:32 PM
[QUOTE][No real need to port the heads unless you can and the engine is apart already. Cam, big exhaust, a little meth good tune and about 13psi should get you into the 500ish range with a 5.3. I think WJmark is just over 500 with a zo6 cam, meth and 13psi.
Tranny will surely go south in a hurry, so you will need to be looking for an upgrade there. ]
13 psi sound kinda high correct me if im wrong cause its been a while since i read the article, but i thought parish got 700-800 out of a junk yard stock 5.3l with a mp70 on 9 or 10 psi and a ls6 cam?
Old 03-27-2009, 06:46 PM
kbracing96's Avatar
I believe they got 600rwhp with a th400, way loose converter, and 9", at 15psi on that MP T70 and 01 ls6 cam.
I made 500rwhp on my 4.8 with a small cam, Meth, MP T70 and 11psi.
Old 03-28-2009, 11:21 PM
k maybe its not high, has that motor blow up yet? it would be interesting to see what a stock 5.3l breaking point would be if you did the tune and turbo setup right.
Old 03-29-2009, 12:09 PM
kbracing96's Avatar
Last I heard, it was still running strong with tons of dyno and track passes
5.3lSilverado
25
08-29-2016 12:48 AM
USMCvet0311
08-14-2015 10:28 PM
05GMC4.8
08-07-2015 09:55 PM
slowlsx
08-04-2015 10:04 PM
Cowboy17
07-09-2015 06:18 PM
Quick Reply: 5.3L Turbo Build
