574rwhp Magnuson "112" using 111LSA cam
stumbled across this and thought it was intersting:
specs on the cam are:
Texas Speeds Magic Stick 4 camshaft 239/242, .649"/.609 111LSA
I helped my good friend install a 112 intercooled Maggie on his 02' Fbody. The car is a stock bottom end, MS4, PRC STG1 heads. I'll just post what he posted. We are overlly happy with the numbers. The MS4 is bleeding down the boost as we but a 3.2 pulley on and the boost stayed at 5.5
Here's his post..
Went to the dyno tonight it was a dyno jet. Weather was about 50 degrees out. I have a 02 camaro z28 6 speed dana 60 rear with 411s in it. Prc stage1 243 heads with a MS4(wasnt planning on putting on a blower ) Anywho its late so ill get pics/vids/graph up tomorrow but it put down 574 horse and 505 ft-lbs
I was hoping for 500 and anything over i would be happy with so im 74 horse happy. The cam is obviously not helping this at all either because its 111lsa to start with. Its made for more of a cam only car but im impressed. Car still has stock bottom end in it stock pistons and rods.
Here's his post..
Tin Foil Hat Wearin' Fool
Well production of TQ is directly related to cylinder pressure and a 111lsa and that much duration is going to have alot of overlap thus bleeding cylinder pressure. Damn good numbers, anyone notice he is only using a 3.2 pulley. IE not spinning the **** out of it so its not a hair dryer up top. Damn good numbers and should make for a good sounding and quick car.
Originally Posted by vanillagorilla
Through a Dana 60 no less.
