6 Lbs of boost is not enough
How do I change this text
42/44 lb injectors is right at the limit at 10 psi. this of course depends on were you live... At sea level you better have meth for anything over 10 psi.... to be safe
With meth, two nozzles and 44, I can hit 15 psi in reno, at sac I can only hit about 13.5, keep in mind the other MAJOR fact is RPM, I shift my $hit at low RPM levels....
Allen did my tune. I am sure he kept it rich to make sure things stayed together...I would say it is rich also. Maybe just by getting that to 11.5 will pick up enough power so I wouldn't need to go to 10 psi.
