.68 or .96ar for 5.3
hey guys i was wondering witch turbo would it work beter with my 2006 5.3 silverado front mount custom made turbo mount - power master t70 .68 or.96ar and up to how much boost will i will put with intercooler and a gt2-3 cam how much rwhp ,thanks for your help
I am using a .68 on a 60-1 and I love it. 400rwtq at 2500RPM ... but I am (currently) using a stock torque converter so I am able to capitalize on the smallish turbo. If you are going to the effort of a cam (that will help in the upper RPM range) then I might go with a little bit bigger AR. You certainly won't lose much down low. How YOU want the power delivery to be may take a little tweaking on AR and/ or torque converter. Just my 2 cents
Bill
Bill
I used to have the 60-1 with a .68 my power dropped off at 5200. I now have a mpt70 with the .96 the engine pulls a lot harder on the top end all the way to 6000. I plan to install my gt2-3 in the next few days. Go with the .96.
not much diference between the two. here is a prety good test for just what you are doing >> https://www.performancetrucks.net/fo...highlight=mp70
Also, I would to see some discussion on turbine size... P, Q, S Trim and so forth.
Bill
I only have dynoed it one time and that was with the 60-1, a 45 shot and 11-12psi. The torque peaked 597 at 4800 and the horsepower was 546 at 5200. The truck would only hit 107mph in the quarter. I liked the instant torque the only problem was I was always in boost. Just barely tip in at 65 and it was in boost. I had to play with the timming tables a lot and reenable burst knock to keep it from pinging at 60-80mph when accelerating at light throttle. I do get better gas miledge now that it doesn't boost every time I speed up.
9 Second Truck Club
That cam should work. What are the rest of the specs on your truck? If you have a decent stall, and gears I would go with the looser AR. If you can keep back pressure down, that cam might work for you.
i have a cold air but not good for the turbo but im putting a intercooler and i have 3.73 electric fans and no stall yet what should i get 3000 or what lose stall. and what do you mean by looser ar. and how can i keep back pressure down im new to the fi induction
9 Second Truck Club
The A/R ratio. Not the converter. A 3000-3200 should be enough. I have a yank 3400, and I should have gone with the 3000. I think I would go with the .96AR with that cam. Are you 2wd, or 4wd?
