8.1 truck injectors on a 5.3 and boost?
Old 02-15-2006, 06:58 PM
MrXerox's Avatar
Default 8.1 truck injectors on a 5.3 and boost?
Hey gang, how much do you think the 8.1 truck injectors are good for boost wise on an otherwise stock 5.3?
Old 02-17-2006, 05:36 PM
MrXerox's Avatar
Anybody???
Old 02-17-2006, 06:25 PM
02sierraz71_5.3's Avatar
are you asking for power numbers or boost numbers?
The 8.1 truck 31lbers are good to around 450-500 the 8.1 marine 42lbers are good to around 600-650. I dont have facts just hypothesizing from what Ive seen.
Old 02-17-2006, 07:48 PM
MrXerox's Avatar
I am wondering if I can get away with running 10lbs of boost on a stock 5.3 with these injectors without having too high of duty cycles....?
Old 02-17-2006, 07:51 PM
I would go with the 8.1 marine 42lbers
Old 02-17-2006, 08:57 PM
MrXerox's Avatar
I know, but I own a set of the truck ones right now...
Old 02-17-2006, 09:14 PM
Banned
ogkevin13's Avatar
u need to feed those injectors with a fuel pump
Old 02-18-2006, 11:27 AM
Bad_Apple's Avatar
Well with stock 5.3L injectors and 10lbs of boost I was turning with them, I blew the tips slap off the tip of the injectors and washed my rings. They can't handle the fuel pressure you will half to run. I've been running 8.1L 38lbs injectors and they have been doing good.
Old 02-18-2006, 12:11 PM
MrXerox's Avatar
38lbs? You mean the marine ones? I thought those were 42?
Old 02-20-2006, 03:43 PM
FlaBouy's Avatar
I run a Vortech blown 5.3L with GM 8.1L Marine injectors and 12PSI boost. My injector duty cycle with 5800 rpm shift points are 115-120 %. I have a walbro GSS341 in tank and returnless fuel system. My truck is being torn down right now to add a cam/stage 2 heads, and 1.85 SLP rockers. Yeah 60# siemens are going on also. I tune with HP tuners and have seen high duty cycles since going to the 3.12" pulley.(12 psi) The only way to guage your correct injector size is to log your tune. I logged a radix blown 5.3L today with a 2.89" pulley and 42# injectors. At WOT and 5500 shift points he was logging 93% injector duty cycles. He had just had a dyno tune last week and was putting out 475 ftlbs/480 RWHP. My setup will be dyno'd on Thursday and I expect to be in the 500 RWHP range with my setup. Again, I run a 58 psi returnless fuel system. If you are running a FMU fuel system then the 42 lb should get you through most whatever you do with the 5.3L Hope this helps....
Quick Reply: 8.1 truck injectors on a 5.3 and boost?
