90mm TB on 01' 5.3L cable driven TB w/ pics.
#21
Originally Posted by BigTex
Looks like the 90mm TB mod is getting pretty popular. Does it need tuning?
#22
Originally Posted by DrX
As far as idle is concerned for the ETC trucks: The TB calibration should be corrected in the tune and if you are running in SD, your VE table will also have to be bang on in the idle cells.
I made the "does it need tuning" post specifically to F8L Z71 since he had just made the comment about taking it in for tuning. He also has a 2001 manual cable throttle body truck.
#24
I'm running SD as well with no idle tuning issues. I suspect the physical airflow design of the SSR TB that I have is closer to the trucks original TB, therefore isn't causing a drastic change in idle airflow compared to the vette LS2 TB. I was suprised to see your idle tuning issues when my setup was fine with or without the MAF.
#25
Looks like the conversion factor for the SSR TB would be somewhere between the 78mm and LS2 TBs because of the smaller radius on 1/2 of the TB. But cold start temp also seems to be a factor as my VE table was derived at average operating temp through AutoVE. First time I fired it up it was inside my heated garage and I didn't notice any idle issues. Even though Desired Idle Airflow and Dynamic Airflow were out of sync the PCM was able to cope with it. Then I let it sit outside overnight at 10 to 20 degrees below freezing. Next morning it started and idled fine in Park but died as soon as I put it gear. There was never a problem once it was warmed up because Idle learning was active over 80*C ECT in my tune.
#26
Ok, last part of this conversion was completed.
I foudn that the Nick Willams TB is thicker than the stock unit (duh) so that really screws with the throttle cable function since our cable isnt adjustable like the F-body units. The TB has 2 locations to latch the T-cable to but in the low setting the TB blade will sit about 1/4 open all the time and on the upper setting you have so much slack you're lucky to ever see more than 60% throttle.
I went to a buddys performance shop and had him cut a piece of steel and weld it to my stock throttle cable bracket then grind everything down so it looked like 1 piece of metal. Then he drilled to ne mounting holes to fit onto the J-Tube after measuring out the cable to ensure I'd get 100% WOT. It came out really nice and with a bit of cleaning up it will look nice polished up or chromed, or painted
I have a couple pics but I am having trouble with the NIC on the one computer that has an FTP program so if anyone wants the pics or can host 1 just shoot me an email.
#28
Originally Posted by thunder550
Really? I installed mine and I get the TPS to read 100% when I floor the pedal. I'll have to pull the intake hose off ans see if it's really tilting the blade all the way.
