Adding A Turbo to a Nonturbo'd Diesel
My dad has a 322 with a 18HP Yanmar I believe and it looks virtually the same as your diesel. I should run this across him.
Are you going to intercool it? Maybe something like an old heater core as a FMIC on the cheap?
Where did you get a turbo that small anyway?
Turbo is straight from IHI. It was spec'ed for the engine, unlike most guys that just find a "small" turbo and bolt it up to make 1psi of boost. This one should make like 10psi.
Heres the thermocouple reader and digital tachometer. Thats max rpm no load. I usually see EGT's around 600F under heavy load. I saw 900F once in the winter with a bigass 2 stage snowblower on the front. This little engine has aluminum pistions with no oil squirters underneith so if anythings going to hit the fan when I get the turbo on it will be them!
This is also a Deere 332, and they are 16hp, most think they are 18 because thats what the 318's are.
Here is a guy that has one of those ebay "smart car" turbos on his cub cadet. I heard it in person, sounds pretty sick!
http://vids.myspace.com/index.cfm?fu...ideoID=9070335
Originally Posted by viciousknid
That turbo is like a novelty item for boost bastards. Put it in your house on a shelf next to your model cars.
Put that bad boy on a go-cart with a really loud BOV.
haha we need a shifter kart frame with a gsxr1300 engine... and that turbo FTMFW!!!!
