aftermarket idlers on radix?
Old 04-12-2007, 07:49 PM
cyazo6's Avatar
Default aftermarket idlers on radix?
Anyone running them for better belt wrap? If so got any pics and who are they made buy? I am thinking of running a 2.8 or 2.9 pulley and want to be able to eliminate belt slip.
Old 04-12-2007, 07:53 PM
Mr. Obvious
nightrunner's Avatar
search for the Metco 100mm idler pulleys mod by grippy
Old 04-12-2007, 07:57 PM
cyazo6's Avatar
alright thanks! I looked before posting but didn't find anything. I think Brian@JPA had something to but I can't get any info on it.
Old 04-12-2007, 09:02 PM
Mr. Obvious
i just remember someone mentioning them in his LONG write-up truck-build up thread
Old 04-12-2007, 09:35 PM
cyazo6's Avatar
thanks nightrunner I found it on one of Holty's posts and he mentions a spacer being used on the install. Now I need to figure out what thats about. Where to put it, how big it is and where to get it?
Old 04-13-2007, 12:54 AM
laynlow77's Avatar
its the same spacer as the stock one, just need two of them apparently. i have it here....
now i just need to order the metco pulleys to use it.
Old 04-13-2007, 09:26 AM
cyazo6's Avatar
laynlow77 thanks for the info and pic!
Old 04-13-2007, 10:14 AM
Moderately Differentiated
dewmanshu's Avatar
hmmm...i don't recall getting a spacer. I remember using the one out of the stock one, but the other didn't need the spacer due to the offset on the stock bracket.
Old 04-13-2007, 12:10 PM
Notorious BIG
Holty's Avatar
that is correct, but if you switch to Metco's or a similar idler setup you will need 2 spacers.
Old 04-13-2007, 12:21 PM
Notorious BIG
Holty's Avatar
https://www.performancetrucks.net/fo...ighlight=100mm
Quick Reply: aftermarket idlers on radix?
