air intake temperature and the effects on performance
Old 06-08-2011, 04:43 AM
  #21
Gadgetized's Avatar
Something is definitely off. Do you remember what the outside air temps were like when Nelson received data to setup your tune? I think you are getting spark knock, and the timing is retarding.
Old 06-08-2011, 04:44 AM
  #22
nonnieselman's Avatar
10bucks says your tune is very consertative.
Have you looked into tuning yourself?
A few degrees of timing and the AFR off some can make a huge diff. My turd of a truck ran low 8s in the 1/8th on 6psi and a 45 shot on a stock lq4.
Whats your AFR?
Old 06-08-2011, 12:00 PM
  #23
TXjeepTJ's Avatar
Originally Posted by CashDudeHomie
Do you have a wideband? Boost and mail-order tune without a wideband is not a good idea IMO.
Yeah, I have a wideband. I should have just went with texas speed for the tune.. they are 20 minutes from me, but I had numerous people said Nelson mail order tune is better lol ... live and learn I guess
Then temps outside were probably about 70 degrees when Nelson sent me my first tune. I just got the PCM with the new tune in today, which it has been consistently 100 degrees the past couple weeks
Whats your AFR?
I haven't looked into tuning myself, I actually wish I would have just, instead of throwing the big $$ for a high performance mail order tune, buy EFI live or something and learn how to do it.. at least that way I could monitor what is going on. The AFR is usually around the low 12's
Old 06-08-2011, 08:47 PM
  #24
TXjeepTJ's Avatar
installed the new tune just now.. feels exactly the same pretty much. My 0-60mph even got worse by almost a second. It's INSANELY sluggish until boost kicks in, I mean you don't feel any g-forces or any force pushing you back into the seat
at WOT the ignition advance was in the 30 range. I don't know what that means maybe someone can shed some light on it?
Old 06-08-2011, 08:57 PM
  #25
sprayedenali's Avatar
THIRTY?!?!?! at WOT????? under boost?????
Old 06-08-2011, 09:05 PM
  #26
MikeGyver's Avatar
No way. Unless it's with 111 octane.
Old 06-08-2011, 09:06 PM
  #27
MikeGyver's Avatar
Or E100.
Old 06-08-2011, 09:15 PM
  #28
MikeGyver's Avatar
It might be 30° at WOT if it is not yet in boost.
Old 06-08-2011, 11:24 PM
  #29
TXjeepTJ's Avatar
lol I might be looking at the wrong thing or something.. I'll get a video of it and post it up while I go WOT and have the camera aimed at the gauges (showing AFR, boost and ignition advance)
Old 06-09-2011, 12:13 AM
  #30
TX Tahoe Z71's Avatar
Subscribed to find out the issue. Best of luck with it.
Quick Reply: air intake temperature and the effects on performance
