All the cold water you want for an A/W set up.
#71
Yes that hose or pieces are included. You acutall put that hose together. Its 2 barbs, with 1 pc AC line and 2 ac hose clamps. The blower trucks do not have to run that hose that short, it was needed to miss the down pipe.
The nitrous plate raises the blower 3/8 of an inch. I will see if I can get some newer pics this week for you.
Mounting plate not really any extra room off to the side of the tank. I gets used up quickly.
#72
I was looking at the boxes you have on your website and I was wondering if this one was larger? Pic on website showed box with fender support in place. Actual size would be great so I can see if the tab off the side for the nitrous box is possible and how long til the chilled water runs out when shut off at wot to run the 1/4. If i called to # on the website would someone be knowledgable about this product to talk to?
#73
I AM A MOTHERF*CKER
Boy, if a fella had some kind of trick carbon fiber runner intake manifold with the IC core right up in the intake, and then paired it with a system like this, I bet that would look crazy trick.
Hm. All you would need is some guy with big cubes and a lot of turbos to test it all out for you.
#74
Unfortunately, I think it wiuld be best to lose the carbon-fiber "blanket" over the top of the engine. That could hold heat in. The tank would go right where your Zex controler is now, so you'd have to find another mounting place for all your nitrous stuff. Not impossible, but it will just take some thought.
#75
The fender support is left off this prototype, it was just a tad to tall to make it fit so I just left it off.
Rick
