ALL procharger guys, get in here
Old 10-20-2010, 09:07 AM
Bad_Apple's Avatar
Ive always had oil in my piping..
Old 10-20-2010, 09:22 AM
Baltimore Whore
Mangled03gmc's Avatar
Ok, do tell. was it alot?? Ever enough to the point you had to clean of your MAF
Old 10-20-2010, 08:51 PM
14 Second Truck Club
double047's Avatar
You try the vent yet?
Old 10-20-2010, 11:23 PM
Baltimore Whore
Yes it worked some to an extent. I need to up the spring pressure in the vent, try again.. It def worked, but still need to address some things..
Old 10-20-2010, 11:49 PM
2004SSS's Avatar
just a little info in superchargerrebuilds
http://www.silveradoss.com/forums/in...6&#entry717986
Old 10-21-2010, 11:56 AM
Bad_Apple's Avatar
Had a good bit at one time always had like a teaspoon or so at the 90o before the intercooler. And yes i have had to clean my MAF before.
Old 10-21-2010, 12:15 PM
Baltimore Whore
I wouldn't send my blower to them. This is the only horror story I have read about them.. It might just be a freak, who knows, things happen.. Def sucks
Old 10-25-2010, 10:37 PM
02Denali6L's Avatar
The vent from the PCV is relocated and hooks into the inlet side right before the blower. If this is still hooked up you are probably just getting oil from blow by out of your crank case... This would be why there is so much oil and no real oil level drop in the procharger. The seals are probably fine.
Old 10-25-2010, 10:40 PM
Baltimore Whore
Na no PCV lines running into the system at all. It is the seal. It seems to have gotten a little better, but none the less it is still there.. Still in the air weather or not to sell it all off and buy a turbo kit.. Again procharger ays this is totally normal Gears are slowly moving in me head
Old 10-26-2010, 07:54 AM
gao8302's Avatar
I'm with blown06 on this one!! I have never had any oil what so ever in my piping.
Quick Reply: ALL procharger guys, get in here
