Almost done w blower install, have a question
Almost done with the Roush install, truck is an '06 NBS and the only thing left is installing the intercooler wiring harness.
There's a relay, a ground, a connector for the pump and couple of cables, one has an eyelet at the end and the other has nothing at the end.
Where do I connect those two?
11 sec. Truck Mod
Basically one with the eyelet is gounded, other wire is a turn on when key is on.
11 sec. Truck Mod
Ok bud here is how mine is hooked up,
Black connector plugs into pump
One white wire is grounded to firewall or inner fender or somewhere convenient.
Other white wire says fuel pump relay on it, it can be wired to the grey fuel pump wire in your main harness, or to another wire that is energized when the key is on, this is so your pump only runs when the key is on.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
There're 2 cables with eyelets at its end, one is a thin cable (like 20 or 22) and the other one is like three times larger in diameter. Which one goes to the firewall? The larger one I assume?
What about the one that's left?
FlowmasterMufflers
07-17-2015 03:26 PM
