Alum. blocks for boost
OK, say I want to go outside the LM7 I currently have.
Can someone give me the RPO codes for aluminum 5.3's that I could use? Then, the alum. 6L?
Which would be compatible w/. Gen3 LS's?
Which are Gen 4?
And, all that I need to convert would be what? I know SD sells some sort of conversion, IIRC, ~ $315.
Oh, & if this make it any more difficult, it needs to be compatible w/. my Radix. I'm not updating that, so the heads must jive.
Which are Gen 4?
LS1Tech Editor
I'm curious as well, I've heard they're around 70 Lbs. lighter or so. I'd like to know the official weight differences because that may dictate me scooping an LS1 for my motor as apposed to an iron block 6.0L.
Fastnblu, have you gotten any Radix numbers or kills yet? Just curious!
get the radix on and then see how much faster you want to go. The 112 is better suited with the 5.3 you have....and it would only be worth going alum if you went 6.2 with gen IV heads that would not fit your radix...but if you sold the radix you could build an alum gen IV NA that would run close to the radix. My set up is faster than a out of the box radix 112.
oh yea TOM, when can you hit milan?? we need to hit the track again...sooner b4 it gets hot.
