am i running lean
am i running lean
im getting 11.2 -11.6 under wot but alot of times on decel in lower rpms ill see mid 15s-16 on my afr. any throttle and it droppes right back down but pulled the plugs today just to check things out and this is what iv got. is the white on the ground strap running lean?
No. I doubt you got an accurate plug reading unless you got the condition for several seconds then killed the engine and immediately pulled the plug. Do you have DFCO enabled in your tune? Who tuned your ve table?
I know in the stock tune fuel is cut completely on decel when there's no throttle input to save fuel. Mine does this as well.
How do the other plugs compare? The electrode tip looks fine, and there's carbon around the tip so it doesn't look like obvious signs of a lean mixture.
05GMC4.8
08-07-2015 09:55 PM
