Another 4.8 turbo build
Old 09-24-2012 | 09:50 PM
  #21
03sierraslt's Avatar
I ran as high as 12psi on 93 before I added meth.
Old 09-24-2012 | 10:09 PM
  #22
Quicklynx's Avatar
Swapping the 4.8L into my GTO. LS6 cam the good one to go with?
Twin Turbo build.
Old 09-24-2012 | 10:28 PM
  #23
fortplainman's Avatar
just copy cooks truck, i almost bought it but couldnt justify for having 2 trucks and both being slow with none really being a good DD.
Old 09-24-2012 | 10:37 PM
  #24
silver-mod-o's Avatar
Hunt&Fisherator
Twin Turbo build.
Starting your own thread would be a good place to start.
Old 09-24-2012 | 10:52 PM
  #25
Quicklynx's Avatar
I'll rephrase it instead. Never meant to come off as a hijack.
The build looks awesome, OP. I see you are opting for the LS6 cam over something custom. I saw you are going for a conservative horsepower goal.
If he wanted to, what kind of power can he expect to make if he wanted to go all out on the 4.8L block with LS6 cam and stock heads? Would you consider using a set of heads like the 243s?
Old 09-24-2012 | 10:56 PM
  #26
beastmode's Avatar
Import Moderator
Originally Posted by smokeshow
Your desired power level will change
I know right... like it ever stops there
Originally Posted by black00chev
Should be able to easily make over 600hp if you have a good tune and are keeping everything nice and cool.
Where abouts do you start maxing out a 255.. 500ish?
I like this.
I want to keep mine fairly tame too, I'd rather sacrifice 50hp for more reliability. I think 450ish is gonna be the magic number for me.
Twin Turbo build.
I'm not sure how the LS6 cam would perform in a TT setup.
Ya I loved Rick's old truck. I got the black valance on order and I'm gonna swap to the OEM mirrors ptm and that'll be all she wrote for the exterior. These headlights have some stress fractures in them I assume from being cleared so will probably replace them at some point too
Old 09-24-2012 | 11:00 PM
  #27
beastmode's Avatar
Import Moderator
No sweat man. As far as the LS6 cam over a custom grind, its mainly because its a proven cam when it comes to boost application that sells for fairly inexpensive. Plus it should have a nice idle.
Check out Foose04 and Jake99, both of these guys are putting down some great numbers through 4.8s (not to exclude anybody else, those are just two off the top of my head).
Old 09-24-2012 | 11:14 PM
  #28
black00chev's Avatar
Slowest turbo build ever!
I do believe most people have said the 255 starts running out of steam on the RETURN style systems around 500-550hp. Thats the reason I went with it for now. So that I wont push myself to far power wise.
Old 09-24-2012 | 11:27 PM
  #29
beastmode's Avatar
Import Moderator
That's the same thing I was thinking lol. 255 and a set of 60lbers will only go so far.
Old 09-24-2012 | 11:32 PM
  #30
Yea exactly! And that's exactly what Im going to be running here soon. Well, all ready have the 255 installed, just need to do the injectors sometime. Then trans stuff, then im turbo ready lol.
