Another catch can question... slight oil smell at idle
Originally Posted by George C....
Valve covers and valley cover to catchcan
Nothing back to motor
Just pull the line out of the turbo route it down in front of engine and install a filter.
Works fine up to around 600-650 hp. Or unless you engine has a hot amount of blow by.
This pic will cause an issue. There's no fresh air coming through.
This one's a Magnum not a Precision. I had the turbo all apart and the drain is definitely on the right side. I redid my drain twice to see if it made any difference but I don't think it's the drain. There is no visible smoke, just a faint scent of burning oil that mixes in somewhat nicely with the ethanol smell.
