Any FI guys running LSXRT intake and 102mm TB?
Old 05-16-2012, 04:37 PM
GMCtrk's Avatar
Sweetlsxs10 has done extensive engine dyno testing on the lsxrt and told me the 92 tb only gave up 5 hp versus the 102 on a 650 hp engine
Old 05-16-2012, 05:02 PM
11 Second Truck Club
Superado's Avatar
He was part of my "further research".
Old 05-16-2012, 08:54 PM
Lucille's Avatar
I don't know about the 5 HP claim. I guess it may depend on the specific FI. I gained 1.5 + lbs of boost going from stock 87 to 102 on my 09 Maggie setup. I have to believe that was worth more than 5 HP.
Old 05-17-2012, 02:59 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
the 90mm flows 1170 cfm and the 105 flows 1580cfm IIRC.
Old 05-17-2012, 04:20 PM
Superado's Avatar
I was talking with John @ TR today and his opinion is to stick with a 92mm as well.
As several other builders and tuners have told me...he said the 102's are a bitch to tune.
He said that with a 346, as I have, that the 92 would definitely be his preferred choice.
He feels that you need a 408 or larger to go w/ the 102.
Old 05-30-2012, 06:59 PM
Superado's Avatar
F.A.S.T. LSXRT intake & rails and 92mm TB being installed
Old 05-30-2012, 07:02 PM
Superado's Avatar
What has everyone done with their steam vents?
I ordered these today...
steam vent fittings
A lot of guys use the ones below...but the ones above are the same fittings and less than 1/2 the price...
other steam vent fittings
Old 05-30-2012, 07:17 PM
ltr450ryder's Avatar
Looks good I use the 102 tb and even on my 408 it has some issues still
Old 05-30-2012, 08:09 PM
skeet's Avatar
TB, think youre right, i talked to Pete Encaudo here a good while back when i went with the FAST car style intake, numbers seem very familar.
so why is there tuning issues with the 102 tb? mine seems to run and idle just fine? then again is this cause of dbc vs dbw?
Old 05-30-2012, 08:12 PM
I have a gauge for that
Atomic's Avatar
Its not such an issue with DBC trucks since the IAC valve does all of the work at idle, but with DBW trucks the small change in throttle angle results in a much faster increase in area (and therefor airflow) than a smaller TB, so it has a tendency to surge.
Quick Reply: Any FI guys running LSXRT intake and 102mm TB?
