any FI guys use(d) a Bosch 040 in-tank fuel pump?
in regards to the Ford GT500 SuperCar pump...
I called and spoke with Tim @ Modular Powerhouse this morning and he said that it would NOT work...same reason I mentioned above...
They don't even run them on older Mustangs that have return style, constant voltage systems...
I run the 044 pump. I made it fit the bucket so it goes in tank. I would actually tell others to run it external and inline with a regular in tank pump.
Rick
you know...I've thought of doing that before...
I mean...Walbro and others say that one of the main things that kill the pump is running the tank low...
well...who doesn't run the tank low? especially at the track where the pump is going to be pounded on the most?
I thought, well, if that IS the case then why not use an inline...in the tank...because obviously, the in-line pump doesn't have to be kept cool by fuel...EVER...so you wouldn't have to be concerned with whether you have to cut up the bucket or not either...
AND...the 044 outflows the 040...which IS the case w/ most in-line pumps vs their in-tank counterparts...sounded like a win/win...glad to see someone has tried it!
Rick...how did you fit a sock or filter to the in-tank mounted, in-line pump?
These are inline fuel pumps, we recommend they be installed between the factory (or another aftermarket) in-tank fuel pump, and the fuel rail. These may be installed in the fuel tank, but some custom fabrication will usually be required. In addition, feeding these inline pumps with another pump (in series), will boost the output of the Bosch 044 fuel pump even higher.
did find this in-tank sock/filter that fits the in-line 044 pump...$50
http://www.jayracing.com/index.php?m...products_id=62
![Icon Eek](https://www.performancetrucks.net/forums/images/smilies2/icon_eek.gif)
R
