Any interest in a twin kit?
Old 02-05-2013 | 09:43 PM
  #121
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Denali08
To where?
Hopefully the customer comes gets it.
Old 02-06-2013 | 04:08 AM
  #122
TURBHOE's Avatar
Originally Posted by TrickPerformanceProducts
Talked with precision a little about internal gated stuff.
The glitch for me is the over all cost is more then external gates.
And the actuators I found are not that tuner freindly with boost spring options.
I was wondering about that. I know an external gate has two references, one to open it and another to use to hold it closed for higher psi. Can that be done on an Internal gate? Or is it pretty much what ever the spring pressure is and a reference line to open it? I mean sure you could limit the amount of pressure to the reference line but it would seem to me that high drive pressure may force it open.
Old 02-06-2013 | 06:38 AM
  #123
TrickTurbo's Avatar
Truck Sponsor
Not just the amount of ports. But being able to get in there and swap springs out.
Old 02-06-2013 | 11:46 AM
  #124
charcold-bowtie's Avatar
A min. 20gpm. That's min.
The more, the faster, the BETTER.
Sounds like an expensive *** water pump.
edit. Actually not too bad.
Old 02-06-2013 | 11:47 AM
  #125
TrickTurbo's Avatar
Truck Sponsor
It's all a perspective.
Old 02-06-2013 | 03:15 PM
  #126
Choda's Avatar
Do u have pics of the intercooler mounted and all the pipes hooked up?
Nice job Rick
Old 02-06-2013 | 05:29 PM
  #127
TrickTurbo's Avatar
Truck Sponsor
None yet. There will be 5 silicones 2 pc of aluminum.
That's the plan anyway. lol
The ic plan is to mount I front of the engine hi. Near the water pump area.
Old 02-07-2013 | 06:39 PM
  #128
sand man's Avatar
whats the advantages of the Air/water inter cooler over the air/air ?
Old 02-07-2013 | 10:55 PM
  #129
TrickTurbo's Avatar
Truck Sponsor
Air/water allow for colder air temps for race application.
Can see below ambient air temps even at hi boost pressures.
Can yield the same daily driver results as air/air.
But the overall cost of a solid air/water kit is more expensive then air/air.
Old 02-07-2013 | 11:40 PM
  #130
smokeshow's Avatar
Mod with training wheels
I hope you mean you can see below ambient air temps with ice in the intercooler reservoir... I'd only recommend A2W for heavy race usage, to be honest. Water takes longer to heat up in the coolant circuit, but also takes longer to release the heat.
Quick Reply: Any interest in a twin kit?
