Any on3 turbo reviews yet?
#22
I have the Trick manifold and an ON3 76mm. The manifold is incredible and the 76mm performed very well on my friend's setup before I bought it. The only real downside is the 64mm backside obviously has some room for improvement.
#23
What is everybody's thoughts on the wastegate location between the different kits? My truck is a 4wd and I'm up in the mountains quite often negotiating some sketchy terrain. I'm a little concerned about the wastegate being so low on the trick/KB kits. For that reason alone I'm leaning towards the On3 kit.
#24
Trick Turbo Manifold
#25
Heck, i'd have to completely redo my crossover if I had one of those trick manifolds. I have used on3 parts, such as their turbo, wg, and bov. I have ran some great times (not used their kit), but the only thing I wanted was a better warranty with the turbo.
#26
#27
You could always get the entire kit without the turbo, no?
#28
#29
As far as which kit I would choose, I'd go with KB, then Trick. I'm obviously biased running one of Kyle's kit but I also personally know him and he's stand up. Also, you're getting hand built kits with KB. ON3 kit is obviously Chinese.
