Any one runnin a cam close to this?
220 226 @.050 564 570 It's a comp cam and I'm looking to put it in the 6.0 build (.030 over forged,stage 2 heads & 10lbs boost) The cam choices seem endless for these motors and I'm sure this one will make power but what about street manors, mileage, etc? Any one have this or close to it that can chime in .Thanks.
That is a tad smaller than the one I had speced for my 370ci/KB 2.8 combo. 223/229 114+4 Cam Motion lobes. I have only run it N/A thus far as I am in the process of installing the KB now. So far the cam is great with my 2400 stall converter. It lacks a little bit below 1500 under load with the converter locked but think the boost will compensate that once the blower is on.
I ran a cam a bit smaller, 220/220 566/566 in my 370. It was on a 120lsa. Idled like stock and made good power. That cam you have should make good power all around and idle with a little hint of rumble. Should be awesome.
Wow, a 120 lsa. Was that with the F1 ? I thought with a FI the lsa should be around 112-114 ?
Yes can't wait to hear the new motor,looks like its going to be a winter project though.
