Anyone had this happen with their tvs 1900?
Old 08-19-2009, 06:51 PM
BigCountryx's Avatar
Originally Posted by leftcoast32
There are different thing that all come into play here. Elevation, Heat and the VVT. The cam could be changed for one that is much better for boost and not economy. The elevation and heat are playing hell with the boost and power.
But what is causing the whine to be so loud? Seems odd with a TVS
Old 08-19-2009, 06:56 PM
FormerVendor
leftcoast32's Avatar
He is running a small 2.8 on the TVS1900 so they make a little noise at that speed.
Old 08-19-2009, 09:10 PM
mmm, i need that then, I miss the whine of my 112hh a little, lol
Old 08-19-2009, 11:43 PM
dbs1's Avatar
I certainly agree that elev and heat are part of the mix. When it cooled to high 60's the other evening is when it finally got past the 6lb mark. The surging is one that is certainly weird, and today the truck set a code for being lean after very light to moderate throttle around town. Got me perplexed?
Old 08-19-2009, 11:53 PM
WJ MARK's Avatar
elevation. my trd tacoma made 6 psi and 8 psi in texas. I bet mos of your problems are from the elevation.
You sea level guys have it waaay to easy!
Old 08-20-2009, 12:07 AM
norris_83's Avatar
does anyone have a calculator for boost and displacment??
for example now on my 6.2 with a 2.8 pulley im running a max of 6.5psi..it does reach 7psi once in a blue moon... ppl kept saying it was due to the displacement?
Old 08-20-2009, 08:50 AM
too many factors will affect boost to make a calculator, displacement, heads, exhaust, cam, compression... and on and on. It's a measurement of restriction not power.
Old 08-20-2009, 09:21 AM
dhpro's Avatar
FIRST...check the torque on all the bolts cause it sounds lots like a boost leak even with the elevation. Use a smoke pencil to be certain there's no leak. I have no experience with the TVS, but if the gasket set up is the same as the MP's then there's always a risk of it having folded or gapped somewhere. A while back my MP112 had similar issues (boost dropped off hard and it sounded different) and it was the gasket leaking. Altitude may play a part, but guys we're not talking about 30,000 feet! Did u check the MAP sensor too...I assume ur not running a SD tune?
Old 08-20-2009, 09:58 AM
High on diesel fumes
thunder550's Avatar
If you're using a scan gauge to measure your boost I'm not surprised. The scan gauge is reading your MAP and giving you absolute pressure (manifold pressure compared to a vacuum), whereas a normal boost gauge will give you gauge pressure (manifold pressure compared to ambient air pressure). I bet if you hooked up a normal boost gauge you would still see your 6+ psi even though the scan gauge shows 3psi. Sounds normal to me. A 5800 ft elevation increase change will kill your power, not to mention that your tune is probably way off as well.
Old 08-20-2009, 10:27 AM
kbracing96's Avatar
Yep, I agree. I live at 4800' and have to make a little over 2psi just to get to 100kPa which is sea level air pressure. Your higher then that, so 3psi of your boost is needed just to get you to sea level air pressure. As Chris said, the scan gauge measure psi based on anything over 100kpa as being boost, where a boost gauge is anything over ambient air pressure (probable about 80kPa where your at) as boost. Elevation kills power in both NA and boosted applications. Superchargers are affected most cuz you can't just turn up the boost like a turbo to compensate.
Quick Reply: Anyone had this happen with their tvs 1900?
