anyone install their wastegate like this?
Old 12-23-2012 | 11:42 AM
Swerve7rpm2000's Avatar
i had mine like this on a single 60mm wastegate log manifold setup and worked pretty well for street use with my manual boost controller
Now i have 2-50mm wastegates, one mounted on the cross over and one right off the log manifold using a ams1000 to control the boost
Old 12-23-2012 | 01:25 PM
TrickTurbo's Avatar
Truck Sponsor
Why is a psi sensor in the top port of the log gate?
Old 12-23-2012 | 02:04 PM
StrokinTBSS's Avatar
Registered User
Both look pretty damn good.
Old 12-23-2012 | 03:47 PM
Choda's Avatar
Can't wait to see this truck up and running. If u guys only knew how much hell he had to go through to get to this point.
Old 12-23-2012 | 05:10 PM
Gadgetized's Avatar
Looks good swerve. Hopefully I can get away with one gate.
Tks for the compliments, can't wait till spring to see what this thing can do.
Old 12-23-2012 | 05:41 PM
That reads the psi behind the gate for the AMS1000 boost controller.... so when i put x psi of co2 behind the gate it will run x#'s of boost.... it actually has a T where co2 goes into the same fitting but this picture dosent show it
Old 12-23-2012 | 08:30 PM
Wilde Racing's Avatar
How do I change this text
Originally Posted by Gadgetized
I inatalled my gate the other day and thought I would share some pics. After reading about installing them I decided to make the air enter straight from the bottom and exit straight out and into the exhaust. I won't be able to see if it keeps my boost from creeping until next spring. It ended up coming out just how I wanted it to.
Looks like you are missing a few bolts in the 80e
Old 12-24-2012 | 05:12 AM
Gadgetized's Avatar
I'm cutting out as much weight as I can. Actually last year I ran the truck without that dust cover. I got one and just put it in place for the crossover pipe. The engine is just bolted in place no sensors are installed. Hopefully this week ibcan tackle that stuff. I'm getting itchy to start it up.
Old 12-24-2012 | 10:50 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Looks great Gadget!
Old 12-24-2012 | 02:09 PM
Onetogofast's Avatar
Sweet!!!
Quick Reply: anyone install their wastegate like this?
