Anyone know if these pulley's will work?
Old 10-20-2006, 12:17 AM
foxySS's Avatar
Default Anyone know if these pulley's will work?
Just curious if these will work with the whipple that's on my truck? Edit: and does anyone know what size is stock on my model?
NON SPONSOR LINK
Old 10-22-2006, 12:58 PM
NubzSS's Avatar
NON SPONSOR LINK
we have 4.250 pully stock. and looking at the pullys for the cobra i'm pretty sure they will NOT work. if you go to the whipple site you can kinda see the two.
Old 10-22-2006, 01:28 PM
foxySS's Avatar
Yeah, I used the calipers and could see it was close to 4". Didn't know what part they measure from though to get the the size. Just wondering why it's so difficult to find pulleys for our setup.
Old 10-22-2006, 07:17 PM
91_bowtie's Avatar
Whipple is the only source that I've found. What size are you looking for? I'll be getting rid of my 4" pulley in the next month or so. 12 psi here I come.
Old 10-23-2006, 07:34 AM
NubzSS's Avatar
how much boost were you making with the 4"
Old 10-23-2006, 11:59 AM
91_bowtie's Avatar
6.5 psi
Old 10-23-2006, 12:15 PM
TahoeSS01's Avatar
Default whipple pulley
Yes - Whipple is the only place I have found them also.
For every change in diameter of 1/8 inch- it changes 1 lb of boost.
Stock should have been 4 3/8 or 6 psi on a 2300 axo unit
So a 4 inch will make 7.5 psi
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
Old 10-23-2006, 03:42 PM
NubzSS's Avatar
thank you for the info.
Old 10-23-2006, 06:16 PM
91_bowtie's Avatar
I have if needed...
4 3/8-6psi
4 1/4 -6.5psi
3 7/8-8.0psi
Hope this helps
Ideally yes; but the cam, exhaust, etc. will make the numbers sway a little. This is being discussed more in the thread about adding headers in this section.
If you don't mind me asking... What did whipple charge you for the pulleys? When did you purchase them? I've seen a range of $60-140 for each pulley. I was the 140.
Old 10-23-2006, 09:54 PM
TahoeSS01's Avatar
Same here with shipping-who has them cheaper like $60???
Quick Reply: Anyone know if these pulley's will work?
