Anyone try tapping the OEM fuel rail ends?
I have done it. You uncrimp the aluminum caps on the ends of the fuel rails. Then you remove the "O"Ringed aluminum plug from the rail. Drill and tap the cap for an A/N fitting. Then drill and file a hole in the aluminum cap into a HEX shape so that it can fit over the installed A/N fitting. Put a new "O"Ring on the A/N modified plug and put it back into the fuel rail. Then slip the aluminum cap over the A/N fitting and recrimp it to the fuel rail.
Jeff
Jeff
Rick
Not really. I'm shooting for 750 RWHP and I know I can't make it on one Walbro or Bosch pump without a TON of Meth. I'm sure two walbros will support the 750 goal but I want to be able to try E85 down the road so the twin Bosch pumps will support the volume.
I ordered a 2l Surge tank the other day but it won't be here for a couple weeks. I'll be mounting the surge tank and the FPR on the secondary battery tray (passenger side at the firewall) with the 2 bosch pumps mounted underneath the tray. The stock OEM line will feed the Surge tank with a -6AN return line tapped into the top of the OEM fuel bucket. I've been looking into running one of those 2 CPU ECMs so you can switch between a 91 octane + Meth tune and a E85 tune at a flip of the switch. If such a beast is a reality, then I'll add a 10 gallon E85 tank where my spare used to be (the twin 3" tail pipes negated carrying a spare) with it's own stock type OEM pump. Then I can switch back and forth between the Gas and the E85 tank. Since the surge tank only holds 2 liters and is constantly being recycled, it will have a minimal effect on the main tank in use. Once I get all the parts collected, I'll do a write-up on the install.
I'm dying to get my shortblock installed but I want to get all the supporting systems in place and running before I install it.
Rick
Rick
He's running a single Bosch 044 intank with an Alky dual nozzle kit maxed out. It was after talking to him when I had him load my 4L80E update that I considered running 2 044's instead of adding a 2nd walbro intank (he ran 2 044's inline on Mark's truck). That and the fact that I picked up a pair of low hour 044's from a road race car for less than single new pump that convinced me to build it right the first time and then leave it alone. Plus down the road if I ever bumpb up to twin Garret GT35's, I'll be able to support their thirst.
Since I'm a California boy with bi-annual smog checks, I wanted to put soemthing together that I could just unplug, remove the battery tray and return to stock for the inspection (after a full day of removing the turbos and putting the stock exhaust back on!).
Rick
Rick
