Apexi ACV-R install question
Old 09-02-2007, 10:55 PM
alanderson1978's Avatar
Default Apexi ACV-R install question
I started installing my boost controller today, and it has an input for throttle position. Looking at the schematics, there are 2 different throttle position sensors on the TAC module. One is pin 1 (dark green wire) and the other is pin 11 (purple wire), both on C1 (tan plug). Will either of these work? The controller can be set up to read 0-5v or 5-0v.
TIA
Old 09-02-2007, 11:39 PM
DrX
DrX's Avatar
They both go from 0 to 5V, but they are not the same. Use the green wire.
Old 09-03-2007, 09:30 AM
It will be this afternoon before I can get back out there, but I'll try that.
What is the difference between the 2?
Now, is there a way to make it read English units. Right now it shows km/hr for speed, mmHg for vacuum, and kg/cm2 for boost.
Thanks
Old 09-03-2007, 09:53 AM
DrX
DrX's Avatar
The 2nd sensor circuit will not provide a continuos signal. It is used as rationality check.
Old 09-03-2007, 09:59 AM
Thanks DrX.
Denali08
08-09-2015 04:34 PM
USMCvet0311
08-01-2015 07:45 AM
sauldgold
07-23-2015 02:15 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: Apexi ACV-R install question
