Autometer Boost and Wide Band AFR Gauges
Old 07-17-2007 | 03:00 PM
BlownChevy's Avatar
blownerator
Great work Joe
Old 07-17-2007 | 03:07 PM
Holty's Avatar
Notorious BIG
Is putting the wideband sensor AFTER the cats something new? I've always heard it should be BEFORE the cats???? Obviously crash dummy knows his stuff, but this is the first time i've heard of someone actually recommending to put it there.
Holty's Avatar
Notorious BIG
BTW Joe, nice gauges!
Old 07-17-2007 | 03:16 PM
BlownChevy's Avatar
blownerator
Been tuning after the cats for a while now.....does not seam to kill the WB sensor.
Old 07-17-2007 | 03:28 PM
RibeiroBJJ's Avatar
Praise The Lowered
Looks good Joe,matches the others perfect....now if I could only get mine hooked up
Old 07-17-2007 | 03:32 PM
leftcoast32's Avatar
FormerVendor
I was told that it would last longer and be more stable further away from the pressure and heat. It is working perfectly, thanks to CrashDummy.
Old 07-17-2007 | 03:34 PM
FormerVendor
Bring it over once you get the exhaust done and we can get it all hooked up for you no problem. It wasn't a bad install, just a Biatch to remove the dash over and over to clearance everything for the back spacing of the gauges.
Old 07-17-2007 | 04:57 PM
WJ MARK's Avatar
looks good! I really need to make time to hook up mine
Old 07-18-2007 | 12:08 AM
thunderwagen's Avatar
I have it about 6 - 8 inches after the turbo in the down pipe.
Old 07-18-2007 | 01:46 AM
FormerVendor
Try moving it back as far as the harness will allow and that should stabilize it some for you. Mine is real nice at operating temps where it is located about 6" past the Cats.
