autometer fuel pressure gauge maxxed out???
I was driving home from Houston today and the cobalt electronic fuel pressure gauge pins all the way high. The truck ran fine, no CEL, the wideband didn't run rich, was at 11.5 in boost....bad gauge? I pulled over to turn the truck off and see if there was any problems. Truck idled fine everything else was normal...bad gauge or sending unit??
Make sure moisture is not getting in the connection at the sending unit. Like has already been said, when the signal is lost it will peg out. Mine stared doing that randomly then after a few times, it started reading ~20# low. I called Autometer and they said to replace the sending unit. Replaced it and has been fine since.
How do I change this text
it is an issue with the gauge/sending unit. I've replaced both and mine does it every once in a while. seam to be more likely to happen turning long road trips... POS autometer.....
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
