Avalanche build w/346 Vette engine
anyone know of a similiar build on the forum? I am swapping out the tired
5.3L with a 346 C5 engine and a RADIX, need head and cam recommendations or combos that work for my daily driver...thx!
havent seen too many of those...isnt it alum block? Thot about that route at first to save weight, but the truck block is so much stronger if u plan to do any over bore that I went LQ9. I'd say u might want more blower (look for an MP122HH or go TVS), and possibly more cubes...once u start down this road ur gonna want more power.
thx
thanks DH, I see you have the heavy beast as well! I have the MP 112 RADIX and short block at home, also the cam (LPE GT series) and 317 heads, what is the best comp ratio to shoot for??? how much boost are you running?
buddy had a LS1 and a procharger and eventually a NV4500 in his 03 avalanche for a while.
right now it has a 408, paxton and a 4l80E
its been done, think the ls1 had some decent top end cam in it from what I remember, with stock heads.
Did one for a friend. Similar, 5.3 forged, 241 heads radix 12 psi boost. Got a used GT2-3 cam for a steal. Avalanche goes like hell! Put the transfer case in auto 4x4 and it lays 6 feet of rubber with the fronts. Very smooth idle and he drives it everywhere. Tows his ZR1 long distances with it too.
sig
thanks, wonder what comp. ratio?
Man, you got it bad like me...Noticed ur signature...
several C5's
C5 Vert/ Andy built A&A 346- D1 Procharged, FLT A4, 14 lbs boost CCW drag pack, yada yada
1999 FRC 640 RWHP 733 RWTQ then 408 w/direct port, then 402 l92 setup 524 n/a
then c5 coupe 403 W/LPE TT 750 kit, FLT A4 700 rwtq...
LOL what u asking for the C5?
several C5's
Didn't know that I had any pics of my vette on here. Yeah, got it really bad. Just got a 2010 camaro too. Anyway the compression ratio is right around 9.5 if I figured it right.
I'm only running 9.3:1 now and its too low - shud be closer to 10 and its costing me more than a few ponies. Boosting 9.3lbs (8 rib setup, 3.0 pulley...and I have a 2.9 in reserve) in current weather (50*) with the MP122HH, meth...etc. With my new BlackBear tune SOTP tells me I shud be well into the 500's RWHP. Now that she's running well, I've been working on handling.
several C5's
several C5's
