Back to the other dark side...TVS2300 here I come!
Old 07-02-2009 | 11:15 PM
  #421
BlackGMC's Avatar
Resident Retard
Originally Posted by thunder550
I thought it wasn't possible to do that in the 99-02 PCM.
I just did it on my friends 2000....
Old 07-02-2009 | 11:16 PM
  #422
thunder550's Avatar
High on diesel fumes
Have a link with instructions by any chance?
Old 07-02-2009 | 11:17 PM
  #423
BlackGMC's Avatar
Resident Retard
Just change G0106 to "Fan #2 Control" and G1203 to "Series Parellel Fans", i think i have some PCM pins if you need them, just PM me your address and I will throw them in the mail
Old 07-02-2009 | 11:19 PM
  #424
thunder550's Avatar
Cool thanks....I've got plenty of PCM pins, lol...got a whole hacked up harness here that I can scavenge. Maybe I'll give that a shot.
  #425
thunder550's Avatar
What pins in the PCM need to be changed? Blue 42 is the standard temp pin I know, what's the other one?
Old 07-02-2009 | 11:20 PM
  #426
BlackGMC's Avatar
Resident Retard
Use the regular pin 42 like before then on the other connector use Pin 33. If Pin 33 has a wire in it, just cut it. It is for the AC recirucalate door for dual climate control ACs...
Old 07-02-2009 | 11:21 PM
  #427
thunder550's Avatar
How did you wire up your harness....what pin/scenario leads to what fan state?
Old 07-02-2009 | 11:22 PM
  #428
BlackGMC's Avatar
Resident Retard
BTW i have been running mine like this for almost 2 years, I have never blown a fuse or burned a relay... Make sure you use heavy enough gauge wire and good relays and you should be fine.
Playing with the settings, AC pressures (best to log those) and turn on/off MPH will keep things nice and cool...
Old 07-02-2009 | 11:25 PM
  #429
BlackGMC's Avatar
Resident Retard
Wiring diagram i used
Attached is my latest tune, you can use these settings for starters and then tweak from there.
File Type: tun
  #430
thunder550's Avatar
Ok I think I get it...looking through my tune file now. Looks pretty straightforward.
