Back to the other dark side...TVS2300 here I come!
#423
Just change G0106 to "Fan #2 Control" and G1203 to "Series Parellel Fans", i think i have some PCM pins if you need them, just PM me your address and I will throw them in the mail
#426
Use the regular pin 42 like before then on the other connector use Pin 33. If Pin 33 has a wire in it, just cut it. It is for the AC recirucalate door for dual climate control ACs...
#428
BTW i have been running mine like this for almost 2 years, I have never blown a fuse or burned a relay... Make sure you use heavy enough gauge wire and good relays and you should be fine.
Playing with the settings, AC pressures (best to log those) and turn on/off MPH will keep things nice and cool...
