Backfiring and sooty plug
Old 03-20-2013, 08:40 PM
TOTM: January 2007
Last Call's Avatar
Originally Posted by Beatdown Z
I wish it would give me a DTC, haha.
I'll try the stethoscope. Also going to double check pressure while driving, even though my wideband tells me it's getting enough fuel.
Thanks for the offer Tim, but i'm running FIC 1000's with EV6 connectors. I have a set of TBSS injectors I can put in it.
Your wideband is showing the air ratio, not the fuel content. A cylinder not firing can actually show lean on your gauge since the there is more oxygen in the unburned air and fuel.
Old 03-20-2013, 09:16 PM
Laid Back
Beatdown Z's Avatar
Well, started checking some things tonight. Was going to just swap #7 injector with number 5, but the little plastic nose fell off into the head. So I had to yank the intake. Figured while it was apart i would ditch all the plastic pieces and lube up the o-rings. And since I had all the injectors out, I hit them with a few shots of brake cleaner.
Get it back together and what do you know, it's running great! I'm actually surprised that cleaning the injectors with brake cleaner fixed it. I will still contact FIC to see about having them cleaned.
Old 03-20-2013, 10:31 PM
MikeGyver's Avatar
Glad I could help!
Old 03-21-2013, 09:01 PM
stall's Avatar
Good deal. Glad u found it. So much for my theory. Haha
twake_410
04-14-2016 09:58 PM
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
02AWDAWSDenali
10-01-2015 05:08 PM
KleanKustoms
09-30-2015 05:07 PM
Quick Reply: Backfiring and sooty plug
