Backpressure
Old 06-10-2012, 01:03 AM
nonnieselman's Avatar
Default Backpressure
Has anyone put a pressure gauge in the exhaust to measure back-pressure?
For a turbo, maybe pre amd post turbo?
Pre turbo would show if the turbo turbine/exhaust housing was a restriction?
And post turbo would show if the exhuast was gettin to its limits of flow and backing up?
I cant sleep and for some reason just thought bout it.*
Old 06-10-2012, 05:38 AM
Mod with training wheels
smokeshow's Avatar
You've got it all right I haven't tested backpressure though. I just run a giant turbine and housing so as to not worry about backpressure lol. When in boost, your boost:backpressure ratio should stay pretty consistent depending on engine specs until either the compressor runs out of steam or the turbine has had all it can take. Higher the ratio the better!
Old 06-10-2012, 01:02 PM
What turbo specs you running?
Old 06-10-2012, 02:29 PM
smokeshow's Avatar
S480 with the 96mm turbine, 1.32ar. Has about a second spool time to full boost from a 30 roll. Not the best, but manageable.
Old 06-10-2012, 02:34 PM
damn!!! thats a huge bitch! What engine?
Old 06-10-2012, 02:44 PM
smokeshow's Avatar
Its a 6.0. Had it on the 4.8 as well...that was some lag and then some! Very little backpressure though.
Old 06-10-2012, 03:14 PM
I bet! I bet it comes on strong around 4k lol. I would love to try a s475 on my 5.3 but I havent maxed out my current setup yet so no need yet.
Old 06-10-2012, 04:44 PM
dirty_old_chevy's Avatar
Smokeshow: at what rpm did you start seeing boost with that turbo and the 4.8?
Old 06-10-2012, 05:04 PM
Dang, thats quite A large turbo.
I dont feel so bad goin with the one im gettin.
S475 75/83 1.0AR
What stall are you running?
Old 06-10-2012, 05:11 PM
where did you get that s475 and how much? T6 flange right?
Quick Reply: Backpressure
