Bad@$$ fuel cell a buddy made.
that pump is fine.... i use them all the time on racecars....
Only reason they fail is because everyone puts a tiny return line ... you must go overkill on the return system ... maybe even on the feed too...
The pump overheats because there is too much press on the return side and if you dont need that much fuel dont use that pump...
Thanks Oleg. On another note, i made this thread to show off my fuel cell and get opinions, not start a fight over the fuel pump. The fuel pump is a personal opinion. I have seen hundreds of them and like said above, if you run big enough lines they will hold up.....even to continuous duty.
Truck Sponsor
Nice tank. Give the pump mfg a call and see how they would want the system set up.
I think your return should be larger then your feed. You want little to zero psi in that line. It can effect how the rest of the system works.
Are your planning to have the pump inside or outside the tank?
Nice freind to do that work for y'all. Post up some install pics once you get it all bolted up.
