Bad@$$ fuel cell a buddy made.
#26
So when you get it all set up and installed couldnt you just check you fuel system bye turning the pump on engine off and watch fuel pressure, then adjust the reg up and down to make sure the fuel presure doesnt creep? That will at least verify that the return size is big enough Yes No???? Nice tank
#28
Well that way you know everything would return fast enough. also with the engine now your not useing any of the fuel. Every fuel system should be able to return everything that its supplied with. For those sudden changes in pressure like 80 lbs at 90% DC then closing the throttle. The injectors shut off but it takes the fuel a second to catch up. If that makes sence
