belt size/radix/smaller pulleys
I can't find any good thread(s) with lots of different radix opinions on belt sizes. I am running the 3.0 and I not real sure what to diagnose on a lower than normal boost scenario(everything mechanical checks out, besides making sure the crank pulley isn't slipping), but with all of this belt dust I have my suspicions.
So after searching through a bunch of threads I'll just start another thread that I know is out there somewhere;
What pulley and belt size are you guys running with your radix setup. Obviously no UDP guys. If you have a gatorback what part number?
Thanks for participating.
thanx, i was reading that the 110.5 is as small as it goes. Any truth to that? If so, belt slip must suck for going to a 2.8 pulley. Or is the gator really that good?
***EDIT***
I see on summitracing.com you can get smaller, just the size increment jumps quiet a bit.
***EDIT***
TOTM: January 2007
***EDIT***
***EDIT***
***EDIT***
***EDIT***
or you can do the 8rib mod, that should work great but more exspensive.
