Belt Tensioner Prob
Old 01-08-2006, 07:18 PM
WaitinToDrag's Avatar
Default Belt Tensioner Prob
For some reason my belt seems to keep slipping off of the tensioner. The belt will come half way off and then excrete a loud whistle. Its actually popped completely off a couple times and I've had to perform open heart surgery on the side of the road. What is casuing this?
For reference: 6.0...Radix...3"....and the belt that came with the 3.4" pulley for the ol 5.3
Old 01-08-2006, 07:49 PM
Destroyer of Transmissions
1SlowHoe's Avatar
What length belt are you using? I think with a 3.4" you should be running a 112" belt. You now have a 3.0" so you prob need to shorten that up. I have a 111.5" belt on my 3.2" pulley. Engine doesn't matter, they all have the same pulley geometry. Just be happy your not snapping tensioners. I have broken 2 in the last 2 weeks. read these...
https://www.performancetrucks.net/fo...d.php?t=355323
https://www.performancetrucks.net/fo...lley+belt+size
I bet you need a 111.0" or 110.5" to keep it from walking off. Just dont go too tight or your alternator bearing will give out...pain in the *** huh?
Old 01-08-2006, 08:02 PM
what a rush!
moregrip's Avatar
How do you know the tensioner is the source of your belt walking off? and under what circumstance does it walk off?
Old 01-08-2006, 08:07 PM
1SlowHoe's Avatar
Yea? I'd love to know whats causing my belt to walk off and let my tensioner snap back and break....
Old 01-08-2006, 08:28 PM
bc the belt is always half way off the tensioner
what else would it be?
Old 01-08-2006, 08:31 PM
what a rush!
moregrip's Avatar
is it half off anywhere else? look at your belt alignment from the side, and what circumstance does this happen?
Old 01-08-2006, 08:41 PM
1SlowHoe's Avatar
Mine does it on a WOT run. I nail it and when I let off I lose power steering. It happened once as soon as I stomped it the other time I went from 45mph to about 85mph and when I let off, no power steering. The tensioner broke both times. Could a belt that is too tight cause this? I have the tensioner almost maxed out so when the belt comes off the tensioner travels all the way back to the stop and SNAP!
Old 01-08-2006, 08:45 PM
nope....i will check the alignment. no particular circumstance that i know of
Old 01-08-2006, 09:12 PM
what a rush!
moregrip's Avatar
just an fyi, here is my set up, 112.5" belt on a 3.1" pulley, zero problems:
https://www.performancetrucks.net/fo...re+pulley+wrap
Old 01-08-2006, 09:14 PM
bud8fan's Avatar
have you changed out the cam or anything else lately...not pulling the pulley all the way in will cause the belt to be misaligned...
Quick Reply: Belt Tensioner Prob
