Belt Tensioner Prob
Old 01-08-2006, 09:16 PM
Destroyer of Transmissions
1SlowHoe's Avatar
Did you ever tell us where to get those pulleys?
what a rush!
moregrip's Avatar
sure did, read the thread
Old 01-08-2006, 09:17 PM
1SlowHoe's Avatar
Originally Posted by bud8fan
have you changed out the cam or anything else lately...not pulling the pulley all the way in will cause the belt to be misaligned...
So the tensioner should be pretty much maxed out toward the drivers side? Let me get a pic...
Old 01-08-2006, 09:35 PM
1SlowHoe's Avatar
Mine look like this. Waitintodrag does your look close to this? Bud8fan?
Old 01-08-2006, 09:45 PM
WaitinToDrag's Avatar
im pretty sure i have a little more slack than that
Old 01-09-2006, 12:05 PM
KySilverado's Avatar
I could see worn crankshaft thrust bearings and crank end play causing a problem.
Old 01-09-2006, 06:15 PM
1SlowHoe's Avatar
Are you saying that just in general or do you think one of us specifically has that issue?
Old 01-09-2006, 08:47 PM
Just in general. Something that would cause an alignment issue. Possibly causing belts to get thrown.
Old 01-09-2006, 10:22 PM
Check to see if the crank pulley has loosened and whobbling.Mine came off so I reccomend pinning the crank pulley.
Old 01-09-2006, 10:25 PM
1SlowHoe's Avatar
I'll check it but I did pin the crank when I did the 6L swap. I think your supposed to TQ the crank bolt to 200lb/ft?? or is it 250? Anyway, I didn't have a tq wrench that would do it. I think I went 150lb/ft and then pushed a little harder. Who know where its at but I checked it a day later and then a few days after that and nothing was loose. But I will check again.
Quick Reply: Belt Tensioner Prob
